Note: This feature may not be available in some browsers.
So several (say, 4) jetski drives could be used to lift a 40' boat off the bottom and pump it out at the surface. Using a similar pump and jet system as the water jetpacks, the pumping equipment could be on the surface while the jets and intakes could be placed on the boat itself.To raise a sunken 40' boat, the amount of flotation needed will depend on the boat's weight and the water depth it's submerged in, but generally, you would need several thousand pounds of buoyant force to successfully lift it
If you compare the quality of the glued inflatables of 30 years ago , to the modern welded seams and material developments , you can have more confidence today.Inflatable PFDs are supposed to be tested to hold pressure every year. Yes, yes I know, most don't. Life rafts every few years.
Imagine the logistics of testing and restowing a full-boat system.
Sadler made unsinkable sailboats. They were 34 feet long. The hull has a liner and the void is foam filled. Obviously the interior volume is reduced, but the safety factor is much higher.
Airbags need proper placement for stabilty when flooded, too low in the hull and they are more likely to invert a boat.
Double skin boats like Etap and Sadler are well proven with very few instances of core issues which have been bought on by owner neglect of deck hardware than factory build issues.
The water bottle flotation does work, but it needs securing behind battens or netting that is secure. I prefer closed cell foam blocks cut to size and removable to squirty foam in non accessible voids.
They built 1,000s between them. It is not that there was anything wrong with the product. Boatbuilders go bust on a regular basis. They have good residual value second hand.Was the concept of the double skin with a closed cell core in between successful? Both companies went out of business, as far as I can tell. You would have thought there would be a ready market for a company with a real product safety advantage.
I would have thought that using a double skin with a foam layer in between would be a great solution but I have read others advise that closing off access to the inside of the hull is not advisable.They built 1,000s between them. It is not that there was anything wrong with the product. Boatbuilders go bust on a regular basis. They have good residual value second hand.
If using foam, is expanded PU good? Or is XPS superior?
I am not up to date with what builders would be using between glass skins at this time. I have used xps type foam boards cut to shape as buoyancy in wooden hulls, but i make sure its accessible. There are a range of inert foams on the market these days such as Diab, water absorbency would be in the spec sheet. Not all foams are equal in this respect.
