I've landed up on this site several times now looking for information, so I thought I might as well sign up.
I have had little quick boats before, row boats, now I want to build one from scratch to exactly what I want.
Basically, I WANT a giant boat, but have decided to build something as big as possible that can tow behind a 1-ton truck.
Weight limit would have to be under 20,000 lbs including trailer.
Width limited to 8' 6"
Length, around 40'
I am not after a sailboat or water ski machine, just a cruiser.
Picture maybe a 40 ft boat, with the middle 20 ft being about the same dimensions as a 20' camper.
I'm thinking of making the hull 4' tall, 8' 6" wide, and square, except for the front and back which would get rounded into something more aerodynamic. Then the cabin would extend about another 4' or so above that.
power wise, I was thinking so far of using a cummins 3.3l 4 cyl diesel. Or something similar. 60-100 HP. Hoping for 10-15 knots out of it.
Basically a powered barge, 8' 6" x 40', with a touch of elegance put to the bow and stern, (more than a 1 angle taper, lol).
I am pretty good at building things, but I've never welded aluminum before...
I am thinking of using 1/4" thick aluminum plate fur the hull. And 3" x 1/4" aluminum bar for framing inside the hull.
I would just use steel, but I don't want the extra work cleaning rust.
So far the only downsides to aluminum seem to be that it might take a while to get the welds right, but from what I've been told, 1/4" aluminum should be pretty easy to weld.
Also, 6051 aluminum?? I see alot of boats are build with 5000 series aluminum, my metal guy only has 6051 aluminum, but says many boats have been built from 6051.
Length, around 40'
