Details about PP core and general core design
I just wanted to clear up some of the fog on polypropylene honeycomb core materials and what I have found through testing and parametric study for use on high production fishing boats and yachts.
:!: GENERAL CORE DESIGN:
(Not directly concerning polypropylene, but core in general) The proper method of design for sandwich structures is to include the effects of transverse shear deformation, or the sliding of the face sheets due to the shearing component of the core during bending. If displacement is of concern, a low value for shear stiffness (as found in PP and many foam cores) will cause larger deflections in reality, usually much larger than isotropic (uniform properties) equations will give you. Some references would be books by Jack R. Vinson or Chandrashekhara or any modern composite plate and shell text. Hexcell also covers this for (oversimplified, but ballpark) semi-composite analysis in their honeycomb design reference which I believe is still free. Diab also discusses it in their online manual.
:!: Generally the ideal sandwich structure has:
* Thin face sheets (you would be surprised at how thin if you use the correct materials and core height) -- (The major weight and cost savings is dramatic for the proper use of sandwich design). (not necessarily core material dependent, the
design philosophy is more important) I have also seen engineers use the same solid laminate and just throw in a core somewhere in the middle, and expect a weight or cost reduction. Strange, huh?)
* A core with extremely low density (PP has at around 5 pcf)
* Low cost (PP is the lowest I've found to date)
* High stiffness (PP is low compared to many foams and balsa,
but how much do you need? Comparison studies will tell you what is best if the proper equations are used). It is important to note here that by nature of materials under dynamic loading, high stiffness materials become brittle and softer ones become stiff, so a study should be performed for the specific application to determine the proper stiffness and strength requirement of the core.
* High shear strength (PP is also low in this category, but the question is emphasized as to
"how much do you need to not fail?" which is answered through rigorous engineering analysis.)
* High strain elongation to prevent catastrophic failure (PP has a very high strain elongation), formability (Honeycomb is inherently the best at this, but the scrim of PP makes it difficult, but can be scored)
* No resin absorption. (PP absorbs very little)
* Little to no print-through at splice joints (PP was excellent compared to balsa for the same resin content)
:!: POLYPROPYLENE HONEYCOMB:
Therefore PP Honeycomb contains most of the important requirements for ideal core, with the exception of the two major ones: strength and stiffness. However, if proper design (designing to what you actually need instead of some arbitrary standard and using the correct equations to carry out the design) is used, the result is exceptional.
Polypropylene is next to impermeable to water. It is also a recyclable thermoplastic with a higher Tg than many thermoset materials and will melt instead of burn eliminating a major energy source for boat fires.
CAUTIONS WITH THERMOPLASTICS AND PP HONEYCOMB:
Thermoplastics are awesome. When I was in aerospace, only the best applications got thermoplastics becaues of their processing expense. They give you the so needed ductility and resilient that thermosets lack and are recyclable, heat formable and cheap. However for combining PP core with thermosets such as Polyester, Vinylester and Epoxy, care must be taken when bonding to thermosets in regions where the scrim has been removed because PP is a thermoplastic. It is effectively a release agent and will not allow chemical bonds to most materials. Ingenuity must be present when bonding at tapered regions, where the scrim is removed. There are methods to do so, such as thermofusing the scrim onto the exposed angled surface with back a vibrating tool.
The key to PP core, is that the increase in height to maintain deflection allowables or reduce facesheet stresses is usually at an insignificant cost and weight increase and a major cost savings and improvement in durability, water resistance and surface appeal foam and balsa. In other words I can achieve the same deflections and stresses as the stiffer materials while also achieving a cost and weight savings by increasing the core height to match the flexural properties.
* Note that I have not discussed plywood. Why? Plywood is technically not a core material. It is closer to a stack of fiberglass than any core material on the market. Although extremely heavy and disastrous in wet and humid environments, it is a very - very efficient material from a specific strength and stiffness standpoint. Its in-plane stiffness jumps the laminate flexural properties through the roof and its shear stiffness properties put even the best balsa to shame, while maintaining in the range of one-third to two-thirds the weight of fiberglass. So by comparison with other core it is too heavy to be used as an efficient core material and by comparison with fiberglass too environmentally unstable to be exposed. As a result, I don't endorse plywood as a good material for structural use in wet environments for dynamically loaded "lightweight" products such as boats.
THERMAL STABILITY?
An issue that I am concerned with and looking into is thermal degradation effects. It has been observed that while ambient air temperatures do not reach 180 degrees F under UV exposure, insulated surfaces such as FG can, (ever burn you feet on hot sand, or on the pavement or on the boat floor?). The mechanical properties as a function of T could play an important factor in the continued use of PP on UV exposed regions. I have been told that it can be autoclave cure with prepregs, which tells me that it should be mechanically sound at these temperatures, but I wonder if anyone has any information or reference about this topic?
I could say more but as long as this thing already is would just be rude.
Thanks
