Hello.
Strip planked 47ft wood/fibre cat. Big double spreader monohull style sloop rig. Wire was 10mm stainless, forestay was 12mm.
My chainplates are original to the boat and since the mast is down Ive decided Id like to replace them. I was wondering if it would be possible to replace them with a composite alternative. The chainplates are located in pairs in line with the mast and have 4 shrouds terminating at each pair
Currently the chainplates are tied into my main crossbeam which is essentially a timber plywood box beam with a series of trusses (think bridge) running between the webs. I have attached a diagram to illustrate the setup. The current setup basically wraps around the beam.
My proposed replacement is to cut slots in the bridgedeck and deck on either side of the beam, then loop around the beam using unidirectional S glass (Or carbon if I can be convinced that its worth it), passing under the bottom of the bridgedeck and over the deck + some sort of mandrel setup for rigging pins. Another drawing attached. In my mind this seems to be a pretty simple replacement of the function of the stainless steel. Since its one layup and it wraps all the way around it should pull up on the whole beam just like the stainless does.
I don't have much experience with boat design and want to make sure I am not on a bad path here.
I prefer going composite over stainless as its cheaper, lower future maintenance, and hopefully truly leak free. I do have fiberglassing experience and work with epoxy quite a lot. It will certainly be a multiperson job.
Can someone point me to a resource to help understanding strength calcs and working towards a layup schedule?
I am unsure about turnbuckle attachment, currently my turnbuckles take a 15mm pin, will that diameter be big enough to build the chainplate around?
What am I not considering or missing?
Thanks in advance
Thanks in advance
