Help with re-power
Discussion in 'Powerboats' started by Barudan_tech, Jun 1, 2009.
  1. Barudan_tech
    Barudan_tech New Member
    I recently acquired a 22ft 1973 Renell Cutty cabin that has been repowered with a 350 Mercruiser Alpha 1 but not completed. I have been looking for info on the distributor that is on it but can’t find anything other than it is a Delco Remy HEI. The engine runs but still needs all the cables hooked up. What I need to know is this distributer suitable for marine application and how would I hookup the Shift Interrupter Switch since the coil is inside?
    I’m also trying to figure out where the power steering pump should mount. Any Ideas?
    Likes: 1,291, Points: 123, Legacy Rep: 2031
    I've never seen a marine version of that distributor. It is a shame because selfcontained units are simple to install.
