Help with Prop specs
Discussion in 'Props' started by allenb, Sep 18, 2009.
  1. allenb
    allenb Junior Member
    Help please ... need help to increase RPMS into recommended range. Have a 2600 Pursuit inboard with 385 single inboard Crusader 8.1L 2008 gas engine. Vessel has gear of 1.56 to 1 made by Liberty Velvet drive tranny. straight shaft to prop is 1 3/8 diameter shaft; two small gland bearings to prop.
    runs great, comes out of the hole to plane quick and light, top end speed is excellent too at 36.8 mph on the GPS with 3/4 full fuel and full water with 2 men on board.
    Only problem is the RPM is a little light ... Crusader says the optimum WOT should be at 4400-4800 RPM with the sweetest spot at 4600 RPM.
    Vessel feels and runs great with a new 16.35 x18 Michigan DQX 4 blade nibral Nibral prop, but WOT RPM is shy and light hitting only 4250 RPM.
    Don't want to lose the top end or cruising speed we have as performance feels fine and we are checking to make sure our tach is correct ... Anyone with any ideas would be helpful???? Thanks
    Allen
    Allen
    Vessel feels and runs great with a new 16.35 x18 Michigan DQX 4 blade nibral Nibral prop, # 4 cup ... but WOT RPM is shy and light hitting only 4250 RPM.
    Allen
    Vessel feels and runs great with a new 16.35 x18 Michigan DQX 4 blade nibral Nibral prop with #4 cup, but WOT RPM is shy and light hitting only 4250 RPM.
    Allen
    Vessel feels and runs great with a new 16.35 x18 Michigan DQX 4 blade nibral Nibral prop, #4 cup but WOT RPM is shy and light hitting only 4250 RPM.
    Thanks
    Allen
  2. hoytedow
    Change to prop of same diameter and slightly less pitch if available.
  3. jehardiman
    Likes: 506, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Or reduce cup slightly
  4. ibrahim.nasr
    ibrahim.nasr New Member
    you may use the same diameter and use slightly less pitch you may submit boat hydrostatics to calculate the right pitch
  5. Corsair_vtt46
    Corsair_vtt46 Junior Member
    reducing pitch is solution.
  6. Boston
    Boston Previous Member
    get in touch with Rick W
    he's in here somewhere
    seems to be the prop pitch guru
    B
  7. gonzo
    Two inches of pitch will increase your RPM by about 300. It should also give you a higher top speed.
  8. Jimboat
    Likes: 16, Points: 18, Legacy Rep: 130
    Jimboat Senior Member
    i'd check your tach to be sure that it's reading correctly, since you're very close the the recommended RPM level. if tach is accurate, and you really want to increase your RPM that little bit to "max", then slightly smaller pitch will increase your RPM. you may have difficulty getting only 1" less pitch, however (even 1" less may be too much) and more than 1" reduction will put your RPM's too high (not good). sounds like performance you're getting now is good, though. There are other things that you could do to your boat setup that could result in performance improvements.
  9. Submarine Tom
    Submarine Tom Previous Member
    Try polishing your prop, how's the leading and trailing edge looking?
    Boat bottom clean? Trim correct? Can you move some of your load
    forward? You're so close and on the correct side for max RPM. Play
    with your variables before you start messing with your prop geometry,
    in my opinion. How's your gas? Oil correct viscosity? Tried "Molyslip"?
    Tom
  10. Submarine Tom
    Engine tuning up to snuff? Plugs okay? Etc., etc...
  11. TollyWally
    TollyWally Senior Member
    Damn good advice from Submarine Tom. If the motor feels close to adequately tuned CHECK THE BOTTOM, then everything else.
  12. allenb
    Allen here ... boat bottom is prefect as is all underwater hardware in working order. Engine is new with only 100 hours on it and running perfect Tach is spot-on as checked with an RPM gun on the fly wheel. So it seems I am indeed left with the prop and going to try for the 1 inch pitch reduction. Thank you all so much. I will report back to the forum once we have altered the prop.
    Allen B.
  13. Submarine Tom
    One inch of pitch is too much I think.
    Can you shallow out the cup a little instead?
    You're sooooo close to what you're after.
    Be careful and good luck.
    Tom
  14. hwsiii
    hwsiii Junior Member
    Allen,you need to remove 2" of pitch to get your motor to 4,800 RPM.
    H
