Help with outboard bracket design
Discussion in 'Boat Design' started by savagescout, Oct 29, 2010.
  1. savagescout
    savagescout Junior Member
    Yeah he mentioned the difficulties of getting the stepped pod dimensions correct in relation to the engine height as a step will change the way the boat performs. His thought was that he had seen many of these boats converted with a stepped pod and a full extension pod and the extension pod was always the safer bet in relation to performance.
    In response to your advice above, i am actually planning to basically extend the hull much like the conversion found here http://www.classicmako.com/forum/topic.asp?TOPIC_ID=10363&SearchTerms=mako
    Essentially the existing transom will become entirely redundant and will be cut out with the stringer/floor structure extended into the new pod/extension. This extension will be a perfect area for batteries/oil reservoirs etc and will allow for a totally different rear combing set-up, transom door etc.
    Lots of planning first before getting stuck in. this is the most important stuff!
