Help with my restoration. Nida stringers/deck
Discussion in 'Fiberglass and Composite Boat Building' started by kpiazzisi, Oct 20, 2010.
  1. kpiazzisi
    Likes: 1, Points: 0, Legacy Rep: 39
    kpiazzisi Junior Member
    You guys are pros, so if it's OK by your standards, then I feel pretty good about the job. If I end up using the Coosa I will post lots of PICS of the material if you are interested?
    Thanks Herman
  2. Herman
    Herman Senior Member
    Yes, please do.
  3. kpiazzisi
    My gas tank has a very snug fit now. I actually have to press or tap it to get the plastic tank to fit in between the two stringers and two bulkheads. I guess when I glued the new stringers in I made them 1/2 CM closer? Is this acceptable, or will it cause a problem?
  4. Herman
    Structurally this should not be a problem. If 1/2 cm in span makes the difference between alive or dead, then you are living on the edge...
    If it is a problem for the tank, I have no idea.
    On METS I saw the Coosa foam. It is the same as the PXc foam of Alcan Airex Ag (A3 Composites). Seems like good foam to me. A bit heavy perhaps.
  5. War Whoop
    Likes: 16, Points: 0, Legacy Rep: 84
    War Whoop Senior Member
    The Deck, I would use a 5 or a 6 pound 1" foam you should need nothing more.
  6. kpiazzisi
    From my research I think the Coosa is better. I researched them both and apparently the Blue water series Coosa is the only one that has both Constant Strand Mat and Roving. UScomposites sells 8LB pourable foam that's described as being the consistency of a soft wood that you could press your fingernails into. That seems a little soft to me? I can get 4 x 8 x 1/2 20LB density for $125.00. I am not sure a thicker lower density board would be cheaper or better?
    KP
  7. War Whoop
    For a deck right and not something you drive a truck over, I was talking about a 6 Pound foam like Corecell not some two part foam.
  8. kpiazzisi
    Would the 1 inch 6LB need lamination
    A huge selling point of the Coosa bluewater series is that it does not need to have a fiberglass laminate on either side. It needs UV protection, but that is it. This is the information I got when I called the company direct and spoke to their customer support. They said that you can laminate the board and this will add to the strength, but in it's standalone form it is a structural product. I am assuming the 1 inch 8lb would have to be laminated? I will probably glass the board either way.
  9. War Whoop
    It is a good transom material where compressive strength in required,but in a deck I would be looking for stiffness and Light Weight both which a foam core sandwich excels in.
  10. kpiazzisi
    Then maybe I should just stick with the Nida? I already have one pannel and would only need two more at $60.00 ea. The nida is ultra light....probably lighter then any foam
  11. War Whoop
    That would make sense at this stage,Do you have a place to mold the panel?
  12. kpiazzisi
    That's why maybe for me the Coosa is better. No mold needed. I am not sure why I need a mold anyway? I was just going to make a templete out of cardboard, trace it onto the nida and then glass one side. Then I could place it into the hull (laminated side down) and glass the top. An alternative would be to glass both sides while on the garage floor and then place into the hull and tab it in.
    The deck is roughly 50 Sq ft. One cu foot of coosa is 20LB. The deck would be 50 Sq Ft x .04 ft (1/2 inch) = 2.1 Cu foot for a totoal weight of appprox 40 Lbs plus the added weight of the laminate. With the nida I will have to use more layers of fiberglass so eventhough the core material is lighter by the time the extra glass is added, it may not be that much lighter. The difference may be as little as 20 Lbs. I don't know if small weight savings is even worth it?
  13. War Whoop
    Just using Coosa for a fore deck, I have not seen that normally done , for the glass internal in that material it is a mute point as you want the skins as far from the neutral axis as possible.you could just use plywood, 1/2" what is the largest span? you still have to join it and put shape into it.
  14. GG
    Likes: 4, Points: 0, Legacy Rep: -30
    GG offshore artie
    So guy if you have to put shape into it are you going score it ?
  15. kpiazzisi
    From what I understand the coosa bluewater series has two layers of roving just under the surface of the foam. So in someways it is still a sandwich concept, just with higher density foam.
    You are correct about having to join the panels that will make up the deck, however the seams will fall directly over the tops of the bulkheads, so the amount of fiberglass to join the panels could be minimal....correct?
    What are you guys referring to when you say "SHAPE". Are you talking about putting a crown into the deck? I called Regal and they said that there is no crowning to the deck. Let me know if you are referring to something else when you say "SHAPE".
    1. jnicho33
    2. fallguy
    3. On283
    4. Roy Senior
    5. Steve_uk
    6. Chapaef
    7. Alex Martin
    8. Ash Spark
    9. CaptTator
    10. Alistair Perrott
