Help with FreeShip
Discussion in 'Software' started by alanrockwood, Apr 4, 2010.
  1. alanrockwood
    Likes: 16, Points: 18, Legacy Rep: 116
    alanrockwood Senior Member
    I am trying to learn to use FreeShip.
    I found a tutorial on line and have been working through it. However, the practice design is open in the back, so it obviously wouldn't float.
    I am trying to add a transom, but it isn't working. I define some points in the transom location, but then when I try to create a face using those points the points simply disappear.
    Any suggestions?
  2. Martijn_vE
    Likes: 24, Points: 0, Legacy Rep: 401
    Martijn_vE Marine software developer
    Are you adding faces to an invisible layer perhaps?
    It seems like that because the moment the face is added the points disappear.
    Make sure all your layers are visible to check this, hopefully your transom will show up.
  3. lewisboats
    Likes: 127, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    Try highlighting the edge line of the hull and extruding it inwards...then shape it to fit.
  4. alanrockwood
    Thanks for the tips.
  5. alanrockwood
    I tried the suggestion to extrude, and it worked.
