Note: This feature may not be available in some browsers.
Well, that's definitely right. We had a huge jump in material costs lately too.The problem is that each builder has a different productivity and a different price/hour. On the other hand, the price of materials can vary greatly from one place to another. Also, with inflation like the one we have, who dares to venture a price?
Well, seems I'll have to contact few boatyards and see what they will say about ti. I hoped there was a aproximative number per kg or lb of materijal weight for solid preliminary estimation. Thank you for replyPrimary materials can be estimated from an approximate surface area, so if you have the basic dimensions you can calculate that. Support materials are more difficult you need experience and a healthy margin.
All materials price depend on location and timing, you can only quote for existing stock.
Labour can only be estimated if you have done this exact type of construction before, so you know how long it takes your crew to plank, fair, glass, etc.
You also have to be very clear about who performs what work. Example strong back, does the NA supply NC cutting files for it and is the cutting done in house? The strips themselves are similar, who cuts them, if they are profiled who does the machining? Depending on your tools, experience and labor rates it can be cheaper to buy the strong back precut, the strips machined and the thickened epoxy in selfmixing cartridges. Add plastic or wooden nails to the mix and stripping becomes very fast, and that cuts labor. It is however the wrong approach if you have a a lot of cheap workforce available or are already tooled up for those specific operations.
