....The captain made an assumption the boat pulling to the right. I have been too nervous to let go! I got you stuck in my bad grammar.
Aaahh.. not so easy to diagnose with a changing narrative!
Note: This feature may not be available in some browsers.
I did not notice a pull one way, but he said I might not unless I let go of the wheel. It is hydraulic steering and surprisingly easy to steer..
Normally with hydraulic steering, there are s.c. block valves that prevent rudder cylinders to force oil through the steering pump. The valves only open when the pump is moved. In this case you don't have to hold the wheel when checking. If the system is lacking block valves, I recommend that they are fitted. When you apply the "brute force", the maximum in/out movement of the cylinder ram is about +/- 3 mm.
Any pictures/drawings of the wet parts of the hulls??
Thanks. I have a liquid tie bar. But am wondering if you are onto something because the description is accurate.How did you go about setting the toe on the motors?
Since your motors are spaced so far apart and installed on a catamaran, I have to wonder if perhaps motor alignment may be causing your issue at high speed similar to alignment issues one might experience in a lightweight sports car and what some might describe as a twitchiness requiring constant input.
On a mechanical tie bar setup, it’s easy to start by disconnecting one motor to find where they naturally want to point, then adjust accordingly and fine tune from there.
Imagine there must be an adjustment on your setup.
You might document current setting and make a change in the opposite direction and see if there is any improvement.
I made a notice on the toe in/out issue in a previous posting. Now also realizing you have a "liquid link", I can only say that these are notorious for instability, you better get rid of it and arrange a solid parallell link. Until then, and with a test as per Ad Hoc, all further speculations are just a waste of time!
Very interesting. But I believe this means new cylinders...A Bowden wire can replace the straight tie-bar between the engines, and be led around the tunnel; it is still a "stiff" connection compared to the "liquid tie bar".
Ok, these images say a lot!
- First it shows the bow down trim, increasing the lateral area forwards. The positive trim you notice when making speed is NOT the bow rising, but the rear sinking due to wave shape and low pressure on the flat bottom "rocker". Hull beam is reducing aft and there is no/low side force acting to compensate for pressure peaks forward.
- Second it shows practically vertical sides from stem and going aft; when yawed, these lines will have a lateral pressure peak forwards (roughly like a symmetrical wing section where the pressure point occurs about 1/3 from the leading edge).
- Third, there is no skeg or fin area aft at all, and the beaching shoes will leave an unstable trailing wake, in which the engine fins don't have lateral authority, ie they do not "steer".
- On top of them all, it seems that the engines have been trimmed down too far (here I'm judging from the video you have shared earlier). Note that with the "rocker" bottom shape, the flow leaving the bottom is inclined upwards. For the outboards to have a neutral trim impact with these lines, they must be trimmed out so that the AV plate has about the same inclination as the hull bottom aft!
- The combined effects of these properties make the hull inherently instable on course.
The good news are that it is quite easy to correct most of the faults causing the problem, but the measures must be applied together with whatever Ad Hoc is planning for the bow.
