help putting a cd player in a boat
Discussion in 'OnBoard Electronics & Controls' started by larryd, Jun 17, 2009.
  1. larryd
    larryd New Member
    I am installin a sony cd player in a 87 bass tracker boat. the boat used to have a tape player. I have taken out the old radio and wired in the new one it is not turning on. I didnt ground it because nothing on the boat is grounded, do i have to ground it right to the battery? and will this make a radio not turn on? p[lease help i am out of ideas.
    Depending on the model, the ground may be on the chassis of the equipment. There should be a ground strip on the back of your panel. That is where the black wire for the lights and gauges
  3. PAR
    That's right, there often is a stud on the back of the unit that will also receive a crimped lug.
    For what it's worth, everything on your boat is grounded, or it wouldn't work. In fact this is a common issue when things fail and one of the first things I check when an electrical device seems to suddenly take a dump. I can't tell you how many times I've made a service call just to tight a 1/4 turn on a ground screw.
  4. blaze_125
    blaze_125 I see the light!
    I don't know if there is an electrical difference between marine and automotive players, but I know in automotive players you need 2 power source to turn on your deck.
    The yellow and red wires.
    Yellow is the constant/memory wire, and red is the "ignition" wire. In the car world, if 1 of those is not connected the deck won't power on. If you are indeed running a car deck with those 2 wires, connect both to the + side of you battery and call it a day. And obvisouly check the ground too. Also, some decks won't power on if the antena is not connected.
  1. Jorda
  2. AngS5
  3. ronald armentrout
  4. yodani
  5. the brain
  6. snowbirder
  7. BertKu
  8. boatofhoha
  9. Dirty Birds
  10. DrinkCoke
