Help Needed on How to Set the Stability of the Generator and Engine for VOLVO KAD-300
AprilSky
Junior Member
Joined
Mar 26, 2025
Posts
12
Reaction score
Location
China
Regarding the VOLVO KAD-300, I would like to set the stability of the generator and engine. Does anyone know how to do this? Thank you in advance!
What do you mean with "stability of generator and engine"? The question does not make sense, what are you trying to do?
@AprilSky
What do you mean by "stability of generator and engine"?
The question doesn't make sense.
What are you trying to do, instal an engine and generator?
To be precise, it's the gain and the stability of a genset and versatile engine.
This may be a language issue. Gain means the amplification of a signal or force. That would not apply to a genset. Versatile, means something that can be used in different applications. An engine for a genset is usually set for constant velocity, which makes it not versatile; unless it is an inverter generator which has variable speed. What do you need stability for? On a generator the stability is usually the voltage or the frequency.
Still no clarity. Are you using an automatic translator? Are you saying that you have a genset with a Volvo KAD 300 engine? If so, what type of generator is it? I've had quite a lot to do with Volvo engines, and the KAD series are designed mainly for propulsion and not what I would use for genset. I really wonder what you're up to.
I've seen the posts by AprilSky and they look like AI. They may be testing the responses.
Yes it crossed my mind as well; no more to add.
