I’m trying to create a perfectly flat 8x4 ft panel using a melamine sheet as the mold surface. For the first panel, everything went smoothly: I applied two layers of Marine Coat One gel coat (about 1 gallon total), then laid epoxy and cloth. I used wax plus PVA as the release system, and the result came out great.
The problem is with the second panel. The gel coat is very thick and hard to spread evenly, leaving thin streaks. When I apply the second layer, it “crumbles up” (lifts) in multiple spots. At first, I thought I hadn’t let the first layer cure enough (I had waited 4 hours), but even after waiting 24 hours on the second attempt, the same thing happened. Each failed attempt costs me about $100 and a week of waiting for more gel coat.
My questions:
My questions:
- Should I just lay down the entire gallon of gel coat as a single coat across the full 8x4 sheet?
- Is there a better way to apply it evenly (brush vs. roller, etc.) given how thick it is?
