HELP!!!-Earthing
Discussion in 'OnBoard Electronics & Controls' started by jollyricard, Nov 20, 2011.
  1. jollyricard
    jollyricard Junior Member
    DEAR ALL,
    HOW CAN I ESTABLISH THE EARTHING SYSTEM ON BOARD SHIP?
    WHAT ARE THE REASONING TO DO?
    many thanks in advance
    best regards
  2. michael pierzga
    michael pierzga Senior Member
    Aww Jeez....a new...EARTH SYSTEM ????
    Ground control to Major Tom...
    Ground Control to Major Tom....
    take your protien pills and put your Helment on....EARTH. ????..
    Ground control to major Tom.... come in Major Tom..Come in.......
  3. gonzo
    Are you asking about AC, DC or bonding?
  4. jollyricard
    Re
    Dear Gonzo,
    many thanks for answer;
    yes, I am asking you info for AC,DC e bonding( onboard ships);
    thank you so much!!!!
  5. hoytedow
  6. gonzo
    Are you trying to comply with a rule?
  7. cyclops2
    Likes: 8, Points: 0, Legacy Rep: 94
    cyclops2 Senior Member
    Size, type & material of the ship ? Salt water or both, salt & fresh water ?
  8. cyclops2
    Found the company.
    look up www.mgduff.co.uk
    They have loads of very good papers covering anything that attacks any type of boat / ship.
  9. CDK
    CDK retired engineer
    In very, very global terms: to avoid voltage differentials. A bird can sit happily on a wire carrying 250.000 volts, but if it had really long legs and could put one foot on the ground, it would go up in smoke.
    Tons of info in this forum, use the Search function.
  10. cyclops2
    This site does have engineers dealing with ship earthing problems.
    I always preferred a " Y " system with the center connection as the ground. It will not tolerate a second voltage as a grounding. I go back in electric power about 53 years.
    People first. Repair any phase that is starting to lose full insulation to ground.
    With todays many different current sensing equipment. ANY VERY SAFE SYSTEM is possible.
  11. cyclops2
    As a observation to safety in tankers & grounding.
    The tanker shipping industry is CHEAP. To allow a ungrounded system in a all metal structure is VERY VERY DANGEROUS to anything that wants to stay alive.
    Try to pull that stunt in a metal mobile trailer. Pure risking peoples safety by most USA electrical codes.
    GREEDY GREEDY oil tanker ship owners. RUN A DAMM full ground to all pieces of any energized equipment !!!!!!!!!!!!!!!!!!!!!!! That code Is HOPEFULLY NOT ALLOWED on any ship transporting Gasoline, Naptha, Natural gas, Propane.
    Anything to make a bigger profit with a known dangerous piece of old equipment.
    "Cost us money to wire the ship correctly."
  12. powerabout
    Likes: 63, Points: 48, Legacy Rep: 719
    powerabout Senior Member
    all the 24v electronics on a ship have isolated negative side ( floating earth) that is supplied via the UPS's or batteries
    The cases of the equipment are grounded to the hull
    Much of the equipment will flag an error if they sense the ground and the negative have a connection
  13. jollyricard
    ok, thanks;
  1. Jorda
  2. AngS5
  3. ronald armentrout
  4. yodani
  5. the brain
  6. snowbirder
  7. BertKu
  8. boatofhoha
  9. Dirty Birds
  10. DrinkCoke
