Help building a 17' long x 50" bottom flat bottom aluminum boat
Discussion in 'Boat Design' started by Loewman, Aug 2, 2008.
  1. buckshot68
    buckshot68 Junior Member
    loewman can you please contact me would like to know where you got your aluminum and where you found a 20 foot break tedsills@gmail.com thanks
  2. buckshot68
    hey loewman would like to know where you got your aluminum and where did you find a 20 foot brake thanks
  3. DDaut
    DDaut Junior Member
    Loewman, How did you bend the ribs in the bow section? Thanks
  4. DDaut
    DDaut Junior Member
    Did you ever find Loewman? I'm interested in building a boat similar to this one. Thanks
  5. DDaut
    DDaut Junior Member
    Did you ever get ahold of him? I'm curious to see how he bent the rectangular tubing to make the rake. Thanks.
  6. thedutchtouch
    Likes: 2, Points: 0, Legacy Rep: 39
    thedutchtouch Junior Member
    any metalworker with the right tools can bend square/rectangular tubing just as easy as round...
  7. DDaut
    DDaut Junior Member
    I'm just trying to find out what tools are needed. Thanks!
  8. thedutchtouch
    you need a square tubing bending tool or jig. the size depends on the size of the tube stock you will be bending. for large radius bends with square material you can build a jig, one example shown here: http://metalgeek.com/archives/2005/05/01/000047.php if it's a smaller radius bend you'll likely need a tool, which can be purchased a variety of places- google "bend square tube". if you dont think you can build your own jig, it'll probably be cheaper to bring your material to a metalshop and have it bent vs buying a tool.
