Hedley Nicol Trimaran Plans
Discussion in 'Multihulls' started by oldsailor7, Mar 12, 2010.
  1. glenn oshea
    glenn oshea Junior Member
    love to see some photos
    i'm just done one up also well no finished yet love to see some photos
  2. cavalier mk2
    cavalier mk2 Senior Member
    Hello Glenn. If you have a Wanderer you're working on why don't you post some pictures too?
  3. glenn oshea
    here are just a few photos will upload some more later
  4. glenn oshea
    when i pulled the under wing ply off i found it full of corthane rapped in newspaper dated 1966 sydney morning herald. good reading and to know year approx and maybe place of build . boat is still australia reg . slow process rebuild but getting there .
  5. Boat Design Net Moderator
    Likes: 114, Points: 43, Legacy Rep: 1004
    If you're using the Quick Reply, click 'Go Advanced' and then click 'Manage Attachments.' Make sure to submit the post after you choose and upload the photos. Hope this helps and thanks. (Longer FAQ)
  6. taow
    taow Junior Member
    hay thanks for that as soon as i get some nice pics ill post them.
    cheers
    Alex
  7. cavalier mk2
    Thanks Glenn, its good to see other people restoring these boats.
  8. catsketcher
    catsketcher Senior Member
    Banyandah
    Gday Glenn
    Banyandah sailed in the only multihull Sydney to Hobart in 1966. It was won by Bandersnatch. I don't think your boat finished. I have to get out my mags to check. It was a light wind race and the fleet did have some drop outs.
    Are you sure you need such a high dodger? It will severely affect your boats windward ability and increase leeway a heap. With their low aspect keels Nicols do not like extra drag above the water. If you cut it down to sit down height under the dodger you could add a headroom height bimini with no front or sides to protect you from the sun without spoiling the boat's sailing charateristics. You also lose a lot of luff length. The best compromise would be to keep the boom lower at the front and have the boom aim up to barely clear the lowest possible bimini.
    You will want to be able to sail well to windward when you are bashing your way south against the soueaters.
    cheers
    Phil
  9. taow
    taow Junior Member
    wow yes it is a high looking dodger you got there glenn is the dogder on in the pic with the blue tarp over where shes sitting on the 44g drums? but looks a nice boat glen very close double to my girl, which im about to try and load some pics now, if my computer doesnt wanna play silly bugger with me tonight
  10. glenn oshea
    dodger
    Hi Phil thanks for you info . yeah dodger does look high but only loose a foot of main sail
    plus shower will be in cockpit are and water catching from roof as well as holding solar panels . also boat has swing down keel that works great 5''6"
    dodger looks higher than it is because its only skinny
  11. glenn oshea
    luv to see some pics
    no dodger not on under tarp luv to see some pics of yours
  12. glenn oshea
    pic of keel setup
  13. cavalier mk2
    Hey Glenn, Renegade , a Vagabond MK2 in Oz has a similar set up. I'll post some pictures after our summer building and sailing of ours. I drew out some swing keels/ centerboards but went with a offset daggerboard trunk though it will be next year before we put the board through. Most of the Nicols have deeper keels now including mine which work fairly well. My dodger manages to be lower because the floor there is dropped to just above the water line with a partition/beam keeping the cockpit water out. Done that way you lose access to the aft berths from the main cabin unless you go for standing room on one side only. Of course the bunks wind up getting moved aft etc....My Vagabond 2 is a different boat but the layouts and options are about the same.
  14. glenn oshea
    hedley nicol trimaran
    some more photo's when i bought it
    had been sitting on hard for nearly 10 years
  15. glenn oshea
    more photos
