Has anyone used MAX GPE epoxy gel coat?
ahender
Senior Member
Joined
Jan 18, 2009
Posts
101
Reaction score
4
Location
Athens, GA USA
MAX GPE epoxy gel coat is available at a good price and seems easy to use. Has a long pot life. A Google search yields nothing. This site, since a search does not acknowledge 3-character terms, yields no results.
Thanks...Alan
What do you plan to use it for?
It appears to be just a normal epoxy with white pigment added.
It even warns about needing a coating for UV protection.
Thanks for replying.
I'm looking for a exterior solid colored white gel coat I can tint for a canoe infusion project (epoxy). I did read about it's lack of UV protection. I thought it might be more abrasion resistant than typical epoxy.
Alan
I didn't see anywhere where it said it was for in-mold use. Epoxies tend to sag and run when sprayed on a mold surface. And spraying epoxy is a bit risky.
There are epoxy compatible gel coats that do exactly what you want and are easy to get. Plus they're UV stable.
Thanks for the feedback. I was going to brush it. I think I'm going to reverse course and use a polyester gel coat and infuse with vinylester. I have asked this question to a potential supplier. Can I infuse vinylester over a polyester gel coat that is still tacky?
Alan
You need to wait until it doesn't come off on your finger, sooner will cause problems.
Brushing works, but like anything else, its a learned skill with gel coat.
