Steve H
Senior Member
- Joined
- Aug 31, 2004
- Messages
- 268
- Reaction score
- 29
- Location
- S.W. WashingtonState
Hello Harley Guys!
Sharper! Your boat is going to be fantastic! I can’t wait to hear that it is finally in the water. The quality of your hull mods, paint, and rigging is beyond me! Pizza, I’m glad to see that you are doing your best to wear out those big CAT Engines! LOL. And raising fish. That is what most Harleys were built to do!
I have been putting a few miles on mine too this year. Mostly on the Columbia River. The odometer says about 2,500 year to date! I will reset it on 1/1, and try to do better in 2022. No real engine or drive issues that I can think of, so not too shabby for the old girl.
I did install a new A/P system. I stayed with Garmin because I know how to use it, and everything else on the boat is the same brand, and it is easy to update the software for all Garmin components at the same time from an app on my phone.
I’m using a steering manifold this time instead of a 12v pump. I never have been happy with the pump system. I think the root of the problem is that Arneson needs fairly high pressure to steer the boat, and the pump was not up to the task. Also, since my boat has gas engines, it is EXTREMELY light weight! And the wind can make the boat a bear to steer at higher speeds. Where as the manifold receives pressure directly from P/S pump. I had to turn the volume down on the manifold on the first seatrial, because the drives were wiggling back and forth way too fast. They looked like a tuna out of water! LOL.
In the past I have used Garmin’s “Virtual” rudder feedback, and have not been confident in it’s performance. This required installing an actual rudder feedback sensor using a custom-made control cable with one end attached to steering ram, and the other end attached to sensor that is located in engine room. So far so good!
The stern thruster is great! Looking back, I should have installed the next size up, but it still works fine for 99 percent the situations I need it for.
I hope everyone had a great Christmas, and are looking forward to piling on the Harley miles in 2022!
Happy New Year from my family to yours!
Steve
Steve
