Today I washed her down in and out and pulled everything in it - all life jackets, safety gear, pillows, cushions, dishes everything to clean as well as possible. Amazing how much crap ends up on a boat.
Cleaned it all, hooked up 2 extra pairs of speakers in anticipation of adding the 8 channel marine AMP....and of course, checked oil, filters, trans fluids, trim pumps and belts. One alternator belt seems to squeak at various rpms so will need to change that out tomorrow.
Also ran engines at the dock - put it gear to test drive shaft alignment etc and something on port motor was vibrating a ton. Check everything I could think of and then dove in with mask to check arnesons - lo and behold port side nut which holds on prop had backed away and was against the cotter pin - prop was wabling around. Pulled nut and it was very thin thread-wise, worn out. I should have noticed this when I re-assembled the props etc on the hard....of course its sunday - no one has it...grrrrr
Will pick up to fresh ones tomorrow morning with a few belts and off we go.
