Gurit scrim on plywood
fallguy
Boat Builder
Joined
Dec 7, 2016
Messages
8,894
Reaction score
2,075
Location
usa
I want to stack Gurit corecell 12mm scrim and cores on okume plywood for a roof. The scrim is glass backed; the core would not be.
First of all, I probably need to preroll the plywood, but then I was hoping to apply a 1/16th" vee troweled thixo and lay the scrim and core pieces onto the prepped plywood.
I think I probably need to prewet the scrim. Pretty sure I can't use vac and weight would be uneven. From past experience; most of the stuff is really sticky in the combinations.
Any advice or concerns?
I did read Gurit's processing guide, it mostly says to test.
My total stack for a lite roof is beams 2.5"wide x 3x 1/2" redwood glueups about a 5" ellipse, with 6mm okume ontop, then the corecell 12mm, then 1200db 2 layers.
I did crack the 6mm ply working on it in one spot; hoping the glassed scrim helps balance point loads better. Comments also welcome on the stack. I would rather not glass the bottom of the stack upside down....will glass patch the crack I made
Back
