Great Multihull Video
Discussion in 'Multihulls' started by Doug Lord, Jan 26, 2010.
  1. catsketcher
    catsketcher Senior Member
    I interviewed both Irens and Coville when Sodebo was launched. The idea was that a sailor could handle a slightly larger tri than an ORMA 60 - about 75ft. So the rig and beam was that of a 75footer. With the rig set at this size you didn't need to go super powerful but you could increase the main hull length without incurring much of a weight penalty and get a large increase in safety downwind. The box rule of the ORMA tris had led to them getting much too square.
  2. Silver Raven
    Likes: 12, Points: 0, Legacy Rep: 67
    Silver Raven Senior Member
    Gooday bloke or Mr. Redreuben - since you don't understand my Qld 'ockerisms'.
    I've spoken at some lenmgth to a number of 'big baoat' multihull sailors - one of the top skippers would be Phil Smith who built, owned & raced a big red tri designed by Lock Crowther. In the end the tri had been fitted with two different sized pairs of 'floats'. Regardless of the difference in wetted surface area, air & water drag & buoyance - Phil still believes that the smaller 'floats' were considerably faster in all conditions. He was one 'hell of a good sailor' & I still learn a lot from talking to him. Big is not neccessarily better, safer or faster. Look at the bottom of the 'floats' of 'Team Australia' - I can see that the shape of the 'floats' is quite different & seems to have a lot going for the highly developed shape. ciao, james
  3. Corley
    Likes: 199, Points: 63, Legacy Rep: 826
    Corley epoxy coated
    Team Vodafone fly by from the bow prod on the Nacra 36 Malice (no slug itself).
    Doug Lord likes this.
  4. Doug Lord
    Doug Lord Flight Ready
    Wow! That is cool! Thanks....
  5. gypsy28
    Likes: 26, Points: 28, Legacy Rep: 120
    gypsy28 Senior Member
    Vodafones not shy about getting up close and personal is she! What a thrill it would be to see an ORMA 60 blast past only metres away:D
    DAVE
  6. Doug Lord
  7. HASYB
    Likes: 17, Points: 18, Legacy Rep: 143
    HASYB Senior Member
  8. Corley
    Corley epoxy coated
    Highlights video from the Lock Crowther Memorial Regatta 2012. Good to see the Pittwater boys sending it!
    http://vimeo.com/51517768
  9. Doug Lord
    Great, Corley-thanks!
  10. Corley
    Corley epoxy coated
    Compilation video from the ORMA 60 Vodafone on the 2012 Coastal Classic
  11. HASYB
    HASYB Senior Member
  12. Corley
    Corley epoxy coated
    from the crew.org.nz forums
    P'zzaz Catamaran a 14 metre cat designed by Shawn Arber sailed in the Coastal Classic 2012 Sail number NZL 7775.
    P'zzaz suprised us enjoying the heavy reaching conditions and winnig the Coastal Classic multihull division on handicap with a fast 10 hours 20 minute trip to Russell, and an adjusted time of 6hrs 48 . Anyway it was a fun ride and we were thrilled to see the speedo showing over 24 knots. Not too bad for a 12 tonne cruising cat. Yay ! Handicap will be shot to pieces now. This video records the trip for crew Paul, Lisa, Derek, Sue and John.
  13. Corley
    Corley epoxy coated
  14. gypsy28
  15. Corley
    Corley epoxy coated
