Glassing In Port Holes of 37' Hatteras
Discussion in 'Boatbuilding' started by gatortennis, Apr 4, 2008.
  1. gatortennis
    gatortennis Junior Member
    I was wondering if I could glass in the port holes on the sides of the hull of a 37' Hatteras sportfish by removing the hardware, applying a couple sheets of glass on the inside, then filling in the hole with marine putty such as isophathalic putty and then sanding, priming, and spraying with Awlgrip?
    Or, What is the recommended way to do this?
  2. KnottyBuoyz
    Likes: 55, Points: 0, Legacy Rep: 685
    KnottyBuoyz Provocateur & Raconteur
    Treat it like any fiberglass repair. There's some good videos from Jamestown Distributors on YouTube that show you every step of the process.
    http://www.youtube.com/watch?v=6N7YMr6E564
    Good luck. Post some pics as you go.
