Gheenoe rebuild
Discussion in 'Projects & Proposals' started by sideshow, Nov 15, 2012.
  1. sideshow
    Likes: 2, Points: 0, Legacy Rep: 38
    sideshow Junior Member
    Or should I frame it out with strips of wood ?
  2. cor
    Likes: 9, Points: 0, Legacy Rep: 85
    cor Senior Member
    What is the metal for? Why add metal to a boat that is all glass?
  3. michael pierzga
    Likes: 114, Points: 0, Legacy Rep: 1180
    michael pierzga Senior Member
    Yah, Metal is not a good material to bond inside a sandwich of glass.
    Best put your thinking cap on and devise a solution to create the shape that is easier to bond or that forms a mold and can be removed when the inside is laminated .
  4. sideshow
    The metal will be used to lay up on . I will wax it and when cured remove the underside metal . I will then add a layer of glass to the bottom side.
    The boat has a lot of radius curves . Today I grinded the inside middle 12'' on each side of where I will be making the cut. Trying to see if I tape then foam the bottom if I can remove the tape/foam nicely and have a perfect line to transfer to wood. I will then fab the metal to sit in the wood and put into position.
    My son cleaning the hull from sanding.
    24'' grinded . I will be cutting at the 12'' mark across .
    painters tape and foam on .
  5. michael pierzga
    Oh, metal used as a mold. That will work.
    Sheet pvc also works. It bends and shapes easy with a heat gun.
  6. sideshow
    No going back now .
    Desired length.
  7. michael pierzga
    Whoa !!
    Two boats !!!!!
  8. hoytedow
    Likes: 195, Points: 73, Legacy Rep: 2489
    hoytedow Wood Butcher
    Nice job on the pull-apart jig. :!: :)
  9. sideshow
    Thank you . I also have screws through the hull for added stiffness. She didn't move at all after the cut and very stiff .
  10. hoytedow
    You certainly don't waste any time. :)
  11. sideshow
    Rough week at work. Put in 59 hours in 5 days. I went in today fabbed and installed the metal mold . Looks god to me. Most likely will clean, wax, buff, and glass next weekend. nervous as hell .
  12. cor
    cor Senior Member
    Looks good.
  13. sideshow
    Glassed 3 layer on the bottom and one all the way up the side . Saying a prayer now. Saturday or Monday I will pull the mold and check the end results.
  14. hoytedow
    It looks pretty good. You gave it a little extra thickness to compensate for the additional stress brought on by lengthening I hope.
  15. sideshow
    Yes I did. Plus I will have 2 2x4 stringers added and I will be adding a full layer on the whole bottom .
