I have installed solar panels on my tiny 38' pontoon houseboat (See Attached wiring diagram) and am having a problem reflecting the grounding for its 120v AC system while at sea and in port.
I have been using all of the 120v AC outlets I installed with no problems, being powered by the Solar panels. However, I have run into a snag. When I plugged in a small 120v AC window air conditioner, its GFCI plug continuously tripped off. I tested all of my outlets which showed correct wiring. Because it is a boat (even though it is currently on a trailer), the grounding connections for both DC, AC, Bonding, and Radio Frequency (RF) components must be grounded to water through the boat's outboard motor by routing grounds through the starting battery's negative post (outboard is grounded to the earth). Researching the problem, SunGoldPower's wiring instructions said to wire the input 120v AC GRID's ground wire to its outside AIO Inverter's housing while the 120v AC LOAD output cable is grounded to a connection inside of the AIO Inverter. Don't know, for sure, that the grounds for the 120v GRID and 120v AC LOAD wires are continuously connected inside the Inverter. Thus, there might be some form of an OPEN ground that the air conditioner's GFCI plug is detecting.
Started researching how to best ground a boat's systems at sea and while plugged into a grounded dock receptacle by watching several grounding related YouTube videos and learned about the shock dangers of swimming around a boat if the boat's grounding design is not exactly correct. Thus, I redesigned the ground wiring as reflected on the attached drawing through an "all" Ground wires connecting Bus Bar to ensure that everything is grounded to the outboard motor's in water surface areas. As reflected in the drawing, I also added a 20 Amp In-Line GFCI for protection against shock while using the 120v appliances inside the boat. I am hoping that rewiring this way will solve the problem of the air conditioner's GFCI plug kicking off. Should I be installing an ELCI instead of a GFCI? If so, why?
I also added an extra 120v ISOLATION (or ByPass) switch. With this "always OFF" switch, I can shut off all of the Solar related (Panels, AIO Inverter, Battery, AC LOAD, and GRID) inputs/outputs at their individual circuit breakers. Then, turn on the added 120v ISOLATION (or ByPass) Switch and use the 120v AC power from the grounded shore plug receptacle, to continuously run my refrigerator and starting battery charger during the periods when the boat is not being used.
If you could just look over the attached diagram to see if I have made any dangerous mistakes in my 120v AC system grounding, I would appreciate it. Thanks in advance. Jim Price
