General sportfish hull-tunnel design questions
Discussion in 'Boat Design' started by buckshot, Jun 16, 2024.
  1. baeckmo
    Likes: 889, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    If there's just one thing you should do, it is blocking off part of the top exit of the tunnels with a crescent shaped segment. Transverse width about 300 mm, height on top ~40 > 50 mm, reducing to 10 each end, and 50 mm long, outer shape to follow the tunnel roof, edges sharp. That will take care of the main ventilation path.
  2. Fiberglass 1 Inc
    Fiberglass 1 Inc Junior Member
    I apologize for possibly being misleading. After looking at another 41 and several other tunnel boats, 4 inch clearance is not unusual.
  3. Fiberglass 1 Inc
    Addendum - I was consulting on a Luhrs 41 a couple days ago and noticed it had the tunnel extensions and also had a prop tip to tunnel clearance of about 1.5 inches. This could be because it had more horsepower and therefore larger diameter wheels.
