Gelcoat or Polysterine lamination on Plug Mold?
Discussion in 'Fiberglass and Composite Boat Building' started by LowelandSystem, May 1, 2016.
  1. LowelandSystem
    LowelandSystem Previous Member
    Hello good fellows,
    Just a help needed as an amateur, should I laminate my plug mold with polyster resin or gelcoat, I am a bit confused :confused: any suggestions will appreciated. TIA
    Likes: 2,235, Points: 123, Legacy Rep: 2031
    You need to use the resin for laminating and the gelcoat as the finish coat.
  3. LowelandSystem
    By curiosity wont epoxy resin wont do, or still I need gel coat. TIA.
  4. gonzo
    The gelcoat builds up a relatively thick layer that has no fiberglass content. That layer is what you sand, fair and polish for a good finish.
  1. mrdebian
  2. Jacob Rogers
  3. Tops
  4. Two beers
  5. itchyglass
  6. itchyglass
  7. itchyglass
  8. mickyryan
  9. hardguy007
  10. T Brown
