Note: This feature may not be available in some browsers.
On this , its the heat cycle of the first part that assists cure of a new/fresh mould, pva as you say styrene resistant. Well applied pva can be heaps shinier than whatever "thing" might be getting copied/moulded. Sometimes if in a hurry it really pays off to pva.I was taught to always use pva on the first part, apparently helps cure the mould and cooks the wax in on the first cycle. Pva makes crummy moulds shine and downgrades shiny moulds but safe
Jeff
On previous molds I always sprayed the gelcoat with the highest recommended mekp ratio to get the fasted geltime and cure as I am aware of the styrene issues. I am interested in the "blow coat" you speak off. Any more info on that?New molds can be not fully cured for a while depending on ambient conditions and other variables.
Plus, if the gel coat you sprayed on the mold doesn't cure quickly the styrene will attack the wax and start bonding to the mold. So new mold, plus slow cure, can result in sticking.
PVA is good insurance on a new mold, or apply gel coat and blow it off. Many tooling shops do a blow coat on everything first, worst case if a few places stick you only need to sand off the gel coat that stuck, no fractures in the mold from wedges and pounding.
The remaining styrene in the partially cured mold and the styrene on the gelcoat likes to shake hands.PVA only provides a styrene resistant barrier between the mold and gel coat, it doesn't really provide any other benefit.
