Gearbox
Discussion in 'Powerboats' started by Poida, Aug 20, 2006.
  1. Poida
    Likes: 50, Points: 48, Legacy Rep: 497
    Poida Senior Member
    I have a gearbox on the end of a 6 cylinder engine I don't know the make but when I have the gear lever in the neutral position the prop still rotates.
    I realise now why I have had difficulties docking as the prop is still running when it shouldn't.
    The gearbox doesn't clunk into gear but rather has a smooth take off.
    I am of the impression that it may have a clutch arrangement. Is it common for small gearboxes to have clutches?
    I don't want to pull it apart if I don't have to and if it is a clutch drive the gap between the plates will increase with wear and overcome the problem by itself.
    However if it is a gear drive I may have to strip it and increase the clearances.
    Incidently it is a timber boat and is a Hartley design.
    Thanks for any info.
    Poida
  1. flyinwall
