G'day fellow cat people, just thought this might help someone... I just bought a 30' open bridgedeck
Discussion in 'Fiberglass and Composite Boat Building' started by Ash Spark, Jul 22, 2024.
  1. Ash Spark
    Ash Spark New Member
    I just bought a 30' open bridgedeck cat, 3 alloy cross beams that go into collars, had to separate the hulls to get it onto a truck and bring home. Got the crane to take the weight of one hull and made this 'slide' setup with a jack to push the hulls apart nice and parallel.
  2. fallguy
    What part of the hull are you pushing on? Is there a BH behind it?
    I have a cat put together with beams as well.
  3. Ash Spark
    The timber (70 X 35) sat just above the deck to hull join, with rubber mat, pic below of the inside. I wouldn't call it a bulkhead but has been reinforced. I lifted one hull from the main/ mid crossbeam, very little deflection.
  4. fallguy
    My boat I ran the beam all the way through and capped it. The joins are sealed with sealant.
  5. Ash Spark
    The Fore and Aft beams go right through. I guess the mid beam is only partial for access.
