ga sblock diesel heads?
Discussion in 'Gas Engines' started by adamanderr, Dec 13, 2007.
  1. adamanderr
    adamanderr Junior Member
    Where should i look for info or possibility of converting a gas block to run on diesel? is it as simple as bolting on compatible diesel heads, since fueling and valve etc are in head? what about having a head machined?
    thanks
    Likes: 1,723, Points: 123, Legacy Rep: 2031
    The only gas engine I know of that was converted to diesel was the Oldsmobile 350 in the 70's. However they used a hardened alloy crankshaft and larger main bearings.
  3. martinf
    Likes: 1, Points: 0, Legacy Rep: 19
    martinf Junior Member
    Can't do this. Diesel's need to withstand huge internal loads as compared to gas engines. For instance, typical comp in a gas engine cylinder may be 150 ps1 and 1000 in a diesel, and, because of this, cranks, rods, pistons...it's all beefed up.
    ~martin
