G4 Primer ?
Discussion in 'Fiberglass and Composite Boat Building' started by nevilleh, Nov 7, 2011.
  1. nevilleh
    Likes: 2, Points: 0, Legacy Rep: 53
    nevilleh Junior Member
    Anyone had much experience of G4 primer? We use it as a primer for plywood decks / bulkheads before applying GRP. Is it really worthwhile using this - Im wondering as most other people that I know just put the GRP straight on to the wood.
    Neville
  2. keith66
    Likes: 19, Points: 18, Legacy Rep: 168
    keith66 Senior Member
    G4 is a one part moisture cured polyurethane varnish often used as a sealer for cheap one shot moulds made directly from mdf or similar. Its primary use is as a pond sealer for concrete, though i have used it for one shot mould making i dont know how well it sticks if used as a primer for grp. I prefer to use epoxy & cloth if glassing decks, its lighter, stronger & sticks for keeps.
  1. fallguy
  2. fallguy
  3. burke
  4. aalbert
  5. nordvindcrew
  6. stimulous check
  7. wind_apparent
  8. stan54
  9. Brands01
  10. mongo75
