FullyElectricAM
Junior Member
- Joined
- Feb 27, 2016
- Posts
- 29
- Reaction score
- Location
- Puerto Maldonado Peru
Good Morning All! I am new to your page and have been skimming it here for about a week. I am very impressed at the maturity and level of dialog this BBS uses. I am not new to this type of system and have served as an Administrator on a few myself, so I know how quickly things can turn. I have been taking the information from the site and I have never built a boat before, so nearly everything I have so far has been taken from PDF books download, website information, and this bulletin board. Bear with me, please! As Bill Hicks would say, "Strap In! Cause here we go!"
I am in the early phases of designing a small cargo ship for life and use in the Amazon Jungle. The river system here has many such vessels operating on diesel engines already. They look like the ships on the following page: http://www.alamy.com/stock-photo/peru-transport-amazon-river.html
The mission of the boat is as follows:
I need to start by designing the ship itself, I would like to build my model on the following information:
Size: 89 feet long x 34 feet wide for the in water hull, 3 decks high at 34 feet from hull bottom to roof height
Weight: 200 tons @ full load
Hull Shape: Flat Bottom
The hull shape will be very standard, with no special designs for cavitation or increased flow to the props. A flat bottom hull is the standard choice for my area and the river system. It will provide stability and consistent drag not to mention be easier to navigate into smaller tributaries and feeding rivers. A two prop system is best, and I think the propellers will be something like 36" with 5 blades at 750 RPM.
All of that information can be altered as this is the earliest stage of building and funding such a craft. Please keep in mind I am building a model of this craft first, selecting a DC propulsion system that will work and stand up to critical review for crowdfunding purposes. I have CAD engineers that want to help build my model for videos, and after we raise the money we will begin actual construction and the plans WILL have to be altered at some point. In other words I am not looking for perfection just a working theoretical model of what the boat will look like and a cost estimation.
Here are my questions: Can I make the craft slimmer in width, maintain the two prop system and the height I want to keep for the ship? Is the prop estimation feasible? If so will the thrust be sufficient to move the boat up river in heavy current?
Thank you for your help, after designing the ship hull, and assigning a theoretical prop, I plan to find a motor that can turn the prop or more likely two brushed DC Motors, and then move toward the battery bank. The Battery Bank will make or break the crowdfunding campaign idea, because this is where the cost gets extreme.
Thank you for reading and I look forward to all input!
Feel free to join me on Facebook at: www.facebook.com/shaneparkscomedy or the page in my sig to follow construction and future events.
This is the justification for the existence, and construction of an electric powered cargo ship working in the river system of the Amazon Rain Forest. Ours is a three part mission devoted to housing volunteers to help build projects, cleaning while protecting, and raising awareness surrounding issues that effect the river system.
First, there are many projects in the Amazon Rain Forest and attached to the river system devoted to sustainability. These projects are often dedicated to permaculture, clean water, clean energy, social impacts for indigenous local communities, and various other causes. Specifically our mission will provide expert building, designing, and supplying of heavy cargo to these projects with a focus on clean energy, clean water, and mitigation of pollution for the river system itself. For example, projects that need to build gasification systems for waste to energy conversion need lots of heavy equipment brought in, experts to help design, expert construction, and integration into the local community. Many of these projects will last for weeks at a time, so housing our volunteers and providing them with comfortable surroundings is a big part of our missions success. Thus our ship will supply these volunteers with a mobile home that can move from project to project without disrupting the lives of the people that live in the area.
Next, to help clean the river system and protect it from future contamination is also a big part of this ships mission. The crew will specifically focus on the cleaning of the river system by gathering plastic and non bio degradable trash as the ship moves from location to location. To accomplish this large netting structures will be dragged from extended arms on the sides of the ship, in addition nets can be dragged behind the boat in the wake. Other ways to gather waste are floating containers that can be dropped and recovered later, gathering trash as they float independently downstream. Once captured the trash will be gathered on board, gasified and turned into energy, clean potable water, thermal heat, and byproducts that can later be used for construction purposes. Another part of cleaning the river system is a proactive approach to mapping dump sites, oil spills, and gold mining run off as the ship travels between locations. This data can be then be transferred and analyzed for information purposes in stationary and ONG groups in the region dealing with these specific issues.
Finally the ship itself will promote raising awareness by simply existing and sharing our sustainable culture on board. We can prove that not only is an electric ship powered by multiple sustainable sources possible, it can also be very lucrative and mitigate its cost due to lower fuel consumption. To do this our ship will be capable of recharging constantly via solar panels mounted on the roof, hydro electric turbine generators that run off river current, wind turbine generators, thermal generators, and waste to energy conversion. Promoting these technologies while in port goes a long way to providing proof of clean energy concepts in this region, and we can also educate the public on how we built our ship and how we can modify our designs to fit various needs both in stationary applications as well as mobile applications like our own.
In conclusion our mission will be a proof of concept that encompasses a wide range of solutions to a vital region of the planet. Providing initiative and momentum to support future projects, protect one of the most vital river systems in the world, and setting a standard that can applied to other vital locations around the globe.
