fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Messages
- 8,938
- Reaction score
- 2,093
- Location
- usa
If the plan is to use the machine screw to engage the upper threads and turn the bottom screw into the plastic, something might strip ( more than likely the plastic ) as the travel per revolution
would be different unless the threads were the same pitch. I am guessing here, but I suspect that the lower screws would be more like a sheet metal screw with a coarser pitch??
Just thowing it out there
the lower screws are machine screws that go into threaded inserts in the roto moulded plastic tank, so those holes are the same as the thread OD or plus a bit, no threads
the top screws could have been engineered larger, but the lidar sensor is sized to work on the tank which is what I did on the portside to get the thing to seal now (removed the badly engineered focuse tube.
