kapnD - You are right about the fuel polisher being a bit of overkill for this engine, but it was a surplus unit from a builder of large yachts that they didn't want to take when they move their facility next year. I got it for about half price and as it has a good gear pump, I'll also use it as my fuel transfer pump as well. It is a 24v system which was the tipping point for me to jump to 24v for the house bank which I think is going to work out well.
I like what you said about the 1-1/2" inserts, I'm starting to feel the same, but haven't quite figured out how to put them into use. As stated earlier, they are on the sides of the tank with the center of the insert about 3 inches above the bottom of the tank. (here is the actual tank)
http://www.moellermarine.com/sites/moellermarine/files/FT5219S-R2.pdf
As you can see, the bottom of the tank slopes sharply downward towards the level of the insert so I guess it is really forming a natural sump. I'd like to plumb in some sort of pick-up tube and valve so that I can seal everything up tight and not have to disturb it later and so it is ready to go when I need it. However, I'm not sure what I actually need. The regular pick up tube goes down to about the same level, so in order to gain some advantage, it seems to me that I need some sort of collection pipe that reaches right to the very bottom. One thought I had was to use the inserts to connect the two wing tanks with an 1-1/2" pipe so to that I can fill both wing tanks from either side of the boat. I haven't quite figured out how to fit that pipe into the engine compartment but I suppose it could be done. I'm VERY open to suggestions!
Michael - The comments you've received about returning hot fuel from the engine to the day tank suprised me. Gerr specifically recommends returning the fuel to the day tank and says nothing about it being too hot. (He also cites a "rule" about always returning to fuel to the source tank.) If you didn't return to the day tank, you really don't have a day tank, you've got about a 2 hour tank
However, cooling the fuel is a good idea and with the location of my day tank, some sort of fin cooler could be added without too much trouble. I'll look into this, thanks.
