french style sailing barge
The river system from the Great Lakes to the Gulf is fairly deep. You can definitely go without problem with a 5' draft.
Yes if you stay in the shipping lanes, but there are all sorts of side places that anything more then 10" it not recommended. I have lived there before. and Some places are inhospitable to the deep V. boats.
I've looked around at boats for sale and have found nothing i liked, besides, since i have some time before need, would like the aspect and pride of knowing that I built something Im going to live on.
I've looked around at boats for sale and have found nothing i liked, besides, since i have some time before need, would like the aspect and pride of knowing that I built something I'm going to live on.
I also want the French style or Toue boat. I have crossed a little bit of deep sea with one and it floated on the surface surprisingly well. Almost like it was surfing. I want to build one myself but can not find plans. The one I was on pulled nose into the beach{sandy} to allow a motorbike to land.
I plan on sailing the water ways down to Mississippi. Most of those are deep enough for heavy cargo , but There are all sorts of small rivers that feed it.
Anyone care to venture into comparisons and advantages of a square sail rig on a boat of this type?
A square rig is about the best for sailing downwind.
But, when sailing upwind of say 135 degrees off the wind, the disadvantages pile up. The first is that you need at least four lines to control the sail, two sheet lines, for the bottom corners of the sail, and two brace lines, to control the angle of the yard. And this is for just sailing down wind. Sailing further up wind, you will need two tack lines, to hold the foreward corner of the sail toward the bow. You may also need bow lines, which connect at about mid-point of the sides of the sail, to keep to keep the windward side from curling inward. So, now we are up to eight lines for a single sail. If you have a lower boom, you can eliminate maybe four of them, which is what the square riggers did. They set one sail on top of another, and often strruck the lowest sail first (which didn't have a spar under it), when it breezed up.
Another problem is the yard, which has to be quite stiff (heavy per material).
A gaff or a sprit sail (the square one with a vertical sprit) will likely be best for you. These are what the working sailing barges usually carried. One of the goals should be to keep the mast as short as possible. This way, you can get beneath more bridges, and it is easier to lower the mast, when you can't. I have read stories about sailing barges getting past low bridges by quickly lowering the mast (with the sails still set!), coasting under the bridge with their momentum, then hauling the mast back up on the other side.
For minimum Sail Area, I would go with: (Length * Beam) + above water profile area. This will work unless the boat is unusually heavy for its Length and Beam.
