freeship and displacement
Discussion in 'Software' started by rapscallion, Nov 23, 2007.
  1. rapscallion
    Likes: 15, Points: 18, Legacy Rep: 132
    rapscallion Senior Member
    Is there a way to figure out the surface area of a hull in freeship so the weight of the design can be calculated? I have a laminate schedule, so it is just a matter of surface area.
  2. Raggi_Thor
    It's in the Layer Properties, area per layer and you can add density and thickness to get weight.
    Have you tried Freeship Plus?
  3. kengrome
    Likes: 25, Points: 0, Legacy Rep: 305
    kengrome Senior Member
    Raggi, I thought Freeship Plus wasn't going to be released for a long time. Is it available now? If so, where?
  4. Raggi_Thor
  5. riggertroy
    Likes: 9, Points: 0, Legacy Rep: 85
    riggertroy Senior Member
    When I installed it it asked me if I wanted to overwrite the existing files, looked at the details and the existing files had a size of zero, chose overwrite and it is working fine
  6. Fanie
    Fanie Fanie
    My Freeship plus and Delftship files are not sharable. Since I've started in Delftship seems I'll have to stick to it or redo it all.
  7. Raggi_Thor
    On my computer I had mixed up "Program files" and "Programfiler" (Norwegian Windows) :)
  8. Victor T
    Likes: 6, Points: 0, Legacy Rep: 58
    Victor T Senior Member
    As default Free!ship Plus to install into "c:\Program Files\Free!ship+" directory. After this you can move this directory Free!ship+ into other disk or catalog, for sample d:\Science\FreeshipPlus. Only uninstall program don't work after this (move back or delete directory freeship+). Delftship can move at the same directory with Freeship+.
    Regards
