1. The Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post boatbuilding tools, drafting tools, molds and tooling, and other professional equipment for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
For Rent ; MVP Pro Rider 22:1 w/ ATG3500
Discussion in 'Marketplace' started by KD8NPB, Jul 13, 2019.
  1. KD8NPB
    Likes: 40, Points: 28
    KD8NPB Senior Member
    I have available for local rent only currently here in Summerville, South Carolina [if you can drive to pick it up, you can rent it].
    Magnum Venus Products
    Pro Rider 22:1 ; Pro Rider Gelcoat System - Magnum Venus Products https://www.mvpind.com/product/prorider-gelcoat-system/
    w/ ATG3500 external mix spraygun ; Air Trigger Guns https://www.mvpind.com/product/atc-chop-gun/
    It can spray at a ratio of 1.5 to 3.25% initiator (9% MEKP recommended), up to approximately 6000 cps viscosity without any issues. Use it to spray gelcoat, VE barrier coat, Duratec 707-002 surfacing primer, or any other low-ratio peroxide initiated coatings. If you have application questions, don't hesitate to ask.
    6 cfm @ 100 psi to run, so it can run off of most medium size hobby air compressors. My Craftsman 2hp/26gal runs it just fine.
    For pictures and booking:
    Meister Integrated Composites, LLC https://www.facebook.com/MeisterLLC
    or
    meistercomposites at gmail dot com
    On site training also available.
