Well, after somebody told me that the keel must be at least partly under the mast, I had to go back to the drawing board.
Please bear with me, one of the biggest problem I had in making my boat is that there is no helper who can assist me, I have to make all errors on my own and try to find solutions for it. While crawling inside in the cabin, there is nobody holding a spanner on the outside, while I could tighten the bolts and nuts on the inside. I have to be very innovative. Nobody to hold a large part, while drilling on my 30 year old table drill or warn out table saw. But I am very pleased with the result.
Photo 1 shows you the roll up sail rod I made with the mast. The cabin tubing bracket to support the mast from both side edges of the boat. Etc. I still have to anodize some aluminium parts, but struggle to find the correct current to do a decent job. Special, in how to do the 4+ meter mast. I was considering a 5 meter gutter and place the mast therein, but my power supply current is limited.
However, I have a question on which I cannot find a solution on.
My gut feeling tells me that I maybe should design stringers to support the mast better, instead of the steel wires straight to the side of the hull and not via a stringer. The length of the mast is 4.6 meter above the cabin roof. The 2 x 3 mm SS steel wire I will have to mount more to the transom. Due to the fact that I have the folding up solar panels at the back and cannot have a wire from mast to the transom.
From the drawing and photo’s one can see the idea I have for the keel.
I have between the centre rollers, for guiding the keelson on the trailer, 50 cm to the next wooden guide to hold the boat on the trailer. The idea I have, is to make a keel which fits nicely between that guide and the centre of the boat and trailer.
The top round tubing is for stability, while the bottom large round tubing, I could fill this with lead to improve and lower my CG as soon I have replaced my 84 kg Lead acid batteries for more Lithium batteries. In the front of the folding up keel, I will have a coil spring. Should I be so unfortunate to hit something, it will slow down the impact. The keel itself is from 3 mm stainless steel.
Well should I use stringers? How far from the top 2/3? Bert
