Foiling radio control trimarans
Discussion in 'Multihulls' started by PerthMini40man, Jun 9, 2016.
  1. PerthMini40man
    Likes: 35, Points: 28, Legacy Rep: 48
    PerthMini40man Senior Member
    Latest video from Sunday showing the tests with 3 foils is here:
  2. UpOnStands
    Likes: 15, Points: 18, Legacy Rep: 16
    UpOnStands Senior Member
    Even better results with quite stable runs -- looking good
  3. Doug Lord
    Doug Lord Flight Ready
    Seems like a slightly nose down attitude-whats your reasoning there?
  4. UpOnStands
    Now reliable foiling gybes seem possible
  5. UpOnStands
    A more comprehensive evaluation of the value of winglets
  6. Doug Lord
    Ian, I'd like to understand your reasoning on this?
  7. PerthMini40man
    It was another way to adjust the angle of incidence on the foils - no particular requirement for the nose-down attitude. The bow-down on the AC cats was for a totally different reason, to get round the limitations of rudder angle adjustment rules I believe
  8. Doug Lord
    Thanks!
  9. PerthMini40man
    Here's the video showing the boat achieving 28 KPH
    Corley and Doug Lord like this.
  10. Doug Lord
    For those not familiar with kph, 28kph= 17.4mph. Great stuff, Ian!
  11. PerthMini40man
    Had another good day on the foils. More breeze than expected
    Doug Lord likes this.
  12. PerthMini40man
  13. FOILFAST
    FOILFAST Junior Member
    Good Day Ian found this thread today , I would like to Float and Fly and develop new ideas,( Your opening statement in starting this thread, struck the right chords) still figuring the site out after joining otherwise would have PM you. For a heads up and starting out phase, and to start will be the only nut out there for a while! but I think that will change. Many Thanks for starting this thread and for all the contributions to it by a dedicated group. Look forward to contributing in due course.
  14. PerthMini40man
    I am back here after the summer break, and to start off with, here is my first Mini40 cat, built over the past few months here in Manila. Main purpose is to test transverse foil cases, as you can see in the photos. Was very satisfying to see the boat foil within 20 seconds of hitting the water
    dddd.jpg fbcat.jpg IMG_8825.JPG IMG_8845.JPG IMG_8862.JPG IMG_8872.JPG dddd.jpg fbcat.jpg IMG_8825.JPG IMG_8845.JPG IMG_8862.JPG IMG_8872.JPG
    UpOnStands and Doug Lord like this.
  15. PerthMini40man
    And here is the video from last weekend. Probably best to turn the sound down as I forgot to blank out the noise of the gas boats...
    I can adjust the beam of the cat by inserting spacer tubes over the cross beam stubs that are epoxied onto the hulls. These slide inside the tubes that are part of the centre pod setup. Very easy to assemble but takes up more room inside the car
    I am also a firm believer in just one rudder on an rc multihull, as I cannot visualise how a leeward rudder and T foil will help foiling
