Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Messages
- 16,679
- Reaction score
- 353
- Location
- Cocoa, Florida
This is an idea I may experiment with down the line with my new test model trimaran. In the interests of having a very simple foil system on the fullsize boat(as well on other applications that might benefit) I've come up with a flapped foil where the bottom of the flap is attached to a spring so that at zero speed the spring pulls the flap down to a 30 degree angle for maximum lift. The spring would be in a carbon tube and could extend forward of the leading edge of the foil. As speed increases the pressure would tend to allow the flap to neutralize. This could be augmented by a very small "trim flap".
The application is limited to boat/foil configurations that do not require downforce or altitude control( this eliminates Bradfield type foilers and most monofoilers) But it fits my ama foil to a tee if we find that the foil needs more manual angle of incidence adjustment than I'm willing to go along with. Or if, by increasing low speed lift, AOI adjustment at mid and high speed range could be avoided since the foil could be set to a lower angle of incidence to start with. It could possibly work on the main foil except that , in its role of working with the rudder on pitch control, the mainfoil needs to be able to develop some down force(active altitude control).
Anyone with thoughts on the concept?
Here is a rough sketch and a picture of the ama foils it might be tried on:
click---
click---
