Hi all,
I'm new to this forum. I'm the kite part of Rob's proa experiments and have been doing some analysis of the hydrofoil setup. I'm flat out with work at present but will make a couple of quick comments {OK, it's got longer than intended...but if you saw the work I should be doing....
}. At this stage I've only been considering the large scale geometry of the setup, not, for example, the section shape - that will obviously need further analysis.
As indicated earlier, the geometry is such that vertical lift is determined by the lateral load from the kite. That is, leeway adjusts such that the horizontal component of lift balances the lateral kite load (ignoring the lateral resistance generated by the hulls). For a given foil angle this determines the total lift vector (normal to the board) and hence determines the vertical lift. As also noted earlier, as the windward hull starts to fly, the board angle (cant/dihedral) changes. As the horizontal lift does not change (ie it is balancing the same lateral load from the kite), the vertical lift increases. So, before considering end span or near surface effects, this would be quite unstable - it would keep rising until leeway was such as to cause stall. I think I was even more surprised than Rob to see quite benign stable performance when we first flew it. So I conclude that end span and near surface effects are significant.
3kN is an upper limit on any loads that the type of kites we're using have generated. (Having said that, we're experimenting with quite different kites which we hope will have a much higher upper limit and provide several other benefits.) I suspect we may have seen loads of up to 2kN and would generally be sailing with less than that. Using Doug's numbers from post #7 (45° elevation, 15° azimuth from beam, foil angle 45°), 2kN would generate twice the vertical load he calculated using a 100 kg (1kN) kite load. So say 1.37kN (ie 137kg weight - forgive me, I prefer to work in N than kg weight and use g=10 for this). Although this is still a bit under Rob's advised mass that is being lifted (180kg), we're really talking about torques here rather than vertical lifting. Consider torques about the lee hull and bear in mind that
a) the centre of lift of the foil is a fair way to windward of the hull and
b) the estimated weight is a at least slightly to leeward of the windward hull, and
c) the horizontal component of the lift vector is contributing some lifting torque.
So somewhat more than 1.37kN force on a longer moment arm than the 1.8kN (180kg weight) weight seems about right. I have done the numbers accurately and it all makes sense. With a few different parameters I estimate a lift coefficient at take off speed (about 4m/s) of 0.18 (span 1.4m, chord 0.3m, foil angle 60° to vertical). At "cruising" height and speed (7m/s, span 0.5m, foil angle 45°) this is only slightly higher at 0.2. These are quite rough estimates but seem to be in the right ball park.
The configuration we have is very attractive for its simplicity and, dare I say, elegance. A single underwater appendage to provide all of flying (ok, it's only one hull!), steering (with the aid of the kite) and lateral resistance has considerable attraction. However, we're considering various ways to improve the downwind/reaching performance and mitigate the heave instability that would arise from high leeway at higher flying angles. One solution is to add a rudder. Although I've a lot more thinking to do on this, the basic aim (apart from steering, which would be a bonus), is to control leeway (and hence lift on the main foil). By raising or lowering the rudder you would effectively be trimming the main foil by adjusting leeway.
When beating the rudder has the effect that as the hull rises, the proportion of lateral lift borne by the rudder would increase. (Although the rudder angle would change with the rotation of the leeward hull, near which it is mounted, this is a small effect as the vertical projection would be the cosine of the heel angle. So I discount this effect in this discussion.) As the assumption is that total lateral lift is constant, lateral lift from the main foil decreases as it flies. Although the vertical proportion of the lift from the main foil still increases with flying height, dynamic analysis reveals this arrangement to be heave stable. Moreover, for given sailing conditions, the stable height is set by the amount of rudder immersed. The rudder taking more of the lateral load clearly also implies better upwind angles.
For strong winds the rudder would be fully immersed whereas for lighter winds a sweet spot may have relatively little in the water - and experience shows that, at least in some conditions with the current foil, no rudder is necessary.
For downwind sailing where we don't fly at deep angles currently because there is insufficient lateral load, the rudder oppose the upwind lift from the main foil. That is, currently we would have negative leeway when going downwind as this is the condition that matches the low lateral kite load. The rudder would mitigate this effect, hence retaining sufficient lift from the main foil to fly....at least that's the plan. There is a clear cost here in that drags from the opposing lifting surfaces would add.
Several other foil configurations have been considered. L, J, inverted L (effectively what we have but with a vertical cap like l'Hydroptere), both to leeward and windward. At present I'm leaning towards the straight canted foil to windward with a rudder for relative simplicity and ease of trimming. But I'm very interested in any other thoughts. (Sorry this has got to be quite so long.)
