Foil Design- Inverted Stacked Tee Foil-High Speed Goal
Discussion in 'Hydrodynamics and Aerodynamics' started by DouglasEagleson, Sep 23, 2016.
  1. DouglasEagleson
    Likes: 2, Points: 0, Legacy Rep: -10
    DouglasEagleson Junior Member
    Here is a design concept for extending the speed range of a sailing hydrofoil. It just uses a smaller high speed foil about 2 feet below the low speed foil. As speed goes up the larger foil leaves the water leaving only the lower high speed foil in the water.
    I use my blogspot as a reference because of lack of internet abilities.
    http://douglaseagleson.blogspot.com
  2. Doug Halsey
    Likes: 152, Points: 53, Legacy Rep: 160
    Doug Halsey Senior Member
    That's not exactly a new idea. Here's Alexander Graham Bell's version of it over 110 years ago!
  3. tspeer
    Likes: 290, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    Mk 105 minesweeping sled:
  4. Gary Baigent
    Gary Baigent Senior Member
    Frog.
  5. DouglasEagleson
    To all commenting on the age of the technology of stacked foils. I did say it is "old technology". I posted it because it did not appear in this forum as a used technology. It is mandatory for altering the top speed of a sailboat on foils.
    It is common knowledge and therefor NOT patentable. But if I can make a change of substantial nature I could get a patent as a derivative of this class of foil design.
    The drag of a single foiler could be altered dynamically by other means such as using aircraft flaps on a water foil. But this is complex machinery. MY patent is just a fine point in foil hydrodynamics giving maybe a few knots of free speed.
  1. 14berlin
  2. RumnCoke
  3. Ale98
  4. schakel
  5. Doug Lord
  6. ltp
  7. radityonugra
  8. markmal
  9. Rohan
  10. radityonugra
