Foil Cavitation at Lower Speeds Than Expected
Discussion in 'Hydrodynamics and Aerodynamics' started by Doug Halsey, Aug 11, 2015.
  1. Ad Hoc
    The video shows wide variations in speeds, from circa 17 to 23 knots in very short time periods.
    This is suggestive of a loss of lift, ergo = the definition of ventilation.
    That doesn't aid matters in narrowing down the culprit with certainty then...
  2. patzefran
    Likes: 30, Points: 28, Legacy Rep: 10
    patzefran patzefran
    Looks like cavitation study is much more complex than it appears in the textbooks......
  3. tspeer
    Likes: 290, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    Most design predictions of cavitation are based on keeping the minimum pressure above the vapor pressure. Up to that threshold cavitation cannot occur. This can be estimated with comparatively simple CFD methods, like panel codes, to get the 3D effects.
    Actually predicting the behavior when cavitation occurs is a much more complex problem. It requires a multi-phase CFD capability in which the water, vapor, and possibly air fluids are all present. The evaporation and condensation of the water has to be modeled. I don't think this is mostly done as an academic exercise and not as a production design process.
  4. BlueBell
    Likes: 415, Points: 83
    BlueBell "Whatever..."
    So which is it Dr Speer?
  5. tspeer
    Oops. Typo. "I think this is mostly done as an academic exercise..."
    BlueBell likes this.
  1. Mikko Brummer
  2. rafa_racer
  3. tlouth7
  4. Eytan Levi
  5. RogerO
  6. Christian Lucas
  7. RogerO
  8. 14berlin
  9. S V
  10. 23feet
