Note: This feature may not be available in some browsers.
International 14--- I wrote to Paul Bieker about CT's comment-this was his response:
Hi Doug,
There is no doubt that the foil made the boats more expensive and a bit harder to handle logistically. That said, they also made the boats significantly faster and easier to sail. I’d hesitate to pin the reduction in new build numbers purely on the hydrofoils. There are bigger trends at work – namely the reduced amount of discretionary income and time that the average person has and the increased cost of building boats in general.
All the best,
Paul
=================================================IMOCA 60 "Charal" launched: Pressure Drop - The New Charal Launches http://www.pressure-drop.us/forums/content.php?8547-The-New-Charal-Launches
>My impression is that there is a much greater emphasis on vertical lift on this particular foil design.
Accueil - Jérémie Beyou http://www.jeremiebeyou.com/
Construction de bateaux et pièces industrielles en composites https://www.cdk-technologies.com/
"En parfaite osmose" is a French common expression to describe the functioning of a team and I think the best translation is "in perfect harmony".
I can confirm you that "osmose" is also the french name for osmosis as regard its first meaning. And osmosis of GRP hull is also a matter of concern, here is a complete overview of the subject by Gerard Boulant, a full time expert on this issue, you can click on each blue texts to have the pdf of all the chapters :Erm, so what do the French attribute gelcoat blistering to? Really, someone ought to clue them in that osmosis has basically one literal meaning in English, and any metaphorical extensions are both informal and off the mark. Symbiosis has the metaphorical sense they want and isn't informal, but it still sounds a bit off, and isn't all that common either.
