float bowl on 6hp evinrude fisherman
Discussion in 'Outboards' started by valvebounce, Apr 19, 2015.
  1. valvebounce
    Likes: 15, Points: 18, Legacy Rep: 124
    valvebounce Senior Member
    On bikes etc,there is a "tickler button"on the top of the float bowl,on the 6hp fisherman one isn't incorporated.
    Is there a vacuum hole or valve on the top of the float bowl ?
    I read on a blog that there is a hole and if you cover it up with your finger the engine runs until the petrol present runs out.Has anyone got any info?
    The engine starts and stops after what I presume is a bowlfull of petrol.
    I am wondering if the hole is blocked and causing a vacuum in the bowl.
    The engine will start again after a few minutes.
