@baeckmo, I think we're on the same page.
Speaking of local loads, as you rightly point out, comparing panels of the same dimensions and thickness, an HDPE panel will flex much more than an RFP or a metal one. And that's certainly true if we're working below the elastic limit. So, I think we're both saying the same thing; we don't disagree at all.
The ISO 12215-5 standard, as far as I know, doesn't take into account the deformation or deflection of the panel at all. It only requires that a certain stress, direct or tangential, not be exceeded at any point along the panel's thickness. It omits deflection, although for me, that's the critical value that must be considered. In my calculations, I always ensure that the panel's deflection doesn't exceed 50% of its thickness. That's a much more demanding requirement than the ISO standard. Aside from the percentage that each of us considers appropriate, I think we agree on that as well.
Regarding the pipework, I have no experience with it and therefore won't venture to comment.
I'm not entirely sure what you mean by a "more elastic" material. But it's clear to me that a material that deforms more than another, without reaching its elastic limit, will give a smoother ride than a more rigid material (by rigid I mean a material that deforms less under the same load). So I think we agree on this as well.
One issue that concerns me, which I asked Bruno about but he didn't seem kind enough to answer, is the safety factor applied when designing with HDPE. Specifically, what design stresses should be used, what percentage of the yield point should be used? Do you have an opinion on this?
Thank you.
