rwatson
Senior Member
- Joined
- Aug 2, 2007
- Messages
- 6,278
- Reaction score
- 545
- Location
- Tasmania,Australia
The Bottom end - bearing and end plate.
I manged to locate a steel, 5 mm end plate for the aluminium column. Usually they only sell Aluminium end plates
Its only held on by some rather small Philips head screws, that I intend to replace with 12mm high tensile boats.
The problem with replacing the Phillips heads with bolts, is that there is a Countersink hole in the end plate, to ensure self alignment.
So, I hunted down some convex stainless washers to put under the high tensile bolt.
