Drua hulls shunt, but have near enough semi circular hulls below the water, a lot of rocker and 4 different bow shapes per boat.
A flat, unrockered hull has less wetted surface than a rockered, round one. But it does not need the weight (and build hassle) of fitted floors, nor the added topside height to get headroom. In a lot of boats, the unrockered, flat hull will be faster in the light.
Water likes to travel in straight lines. Failing that, gentle curves. These (not "plain rectangular wedges") are required for brick sections to transform to pointed bows and sterns. These are the waterline shapes of the village suitable boats we are building. In limited testing, they work well, and are easy to build with flat panels.
A data point or 3: The prototype
24m, 3 ton cargo proa hulls, 2 x telescoping masts, rudders and beams and it's 8.5m tender are built from infused, uncored flat panels and right angle shapes where possible (bricks transforming gently to pointed ends). It took 2 slow old guys 2 years to build, having weekends and holidays off and usually working 8 hour days. Because it was a new design and build technique, there was a lot of chat. Because we liked to experiment, there were a lot of samples built, tested and busted. We didn't get it quite finished (fortunately, as it had to go into 2 x 12m container for shipping to Fiji), and the finish is agricultural, but I'd say between 1/3 and 1/2 of the time could have been saved if plans existed and were followed. So 50 x 40 hours x 2 = 4,000 hours, which could be 2-3,000 with plans and motivated workers. We are waiting for MSAF approval for the boat, then expect to build several of them, so I should get a better idea of the hours.
Attached is the video that should have been in my last post. 2 x 315W panels (less than 1 hp), a converted to electric petrol outboard with a too small prop, no batteries. 3 large people on a 6m barge hull with ski tip bow. Just after high tide, so maybe 0.5-1 knots of tide. 4 knots by gps across the tide earlier in the day.
The next iteration, which the students have just started, is a catamaran with low bridgedeck. Empty, it is self draining; driver only, the rear of the bridge deck is immersed, becomes a planing/lifting surface; with 8 people on board, it becomes a barge, but with conventional pointed bows either side of a ski tip front on the bridge deck.
