Flat plate rudder vs naca drag
Discussion in 'Hydrodynamics and Aerodynamics' started by 23feet, Mar 20, 2016.
  1. 23feet
    Likes: 12, Points: 8, Legacy Rep: 10
    23feet Junior Member
    Hi Dennis,
    Thanks. I think that would be a great solution except the boat is on a drying mooring, and I think it would be a bit hard on the rudders.
  2. rwatson
    rwatson Senior Member
    Not much point on a Wharram. The hull is deep enough to hit things before the rudders do.
    No, its not a good idea. The skeg is there for improved control while sailing. Some of the bigger versions have a retractable forward tab as well.
    James Wharrams imitation of a Polynesian hull has resulted in problems with directional stability when reaching under a modern rig.
      File size:
      150.9 KB
    1. Dieter51
    2. Christian Nally
    3. Andrew Kirk
    4. Jeff in Boston
    5. Greg Dunn
    6. RogerO
    7. RogerO
    8. Roflhat
    9. SailorDon
    10. filo
